1994 Accord Fan Problems/ overheating issues
Old Jun 12, 2016 | 10:40 AM
ls1formula98's Avatar
Default 1994 Accord Fan Problems/ overheating issues
So, from what I can understand from looking over these forums is that when i start the car and turn on the ac, both fans are automatically going to come on correct? I do understand that neither fan is supposed to turn on with the ac off when first started. Until the temp goes above a certain temp and then the radiator fan kicks on. The problem I am having is that neither fan works when ac is turned on. My question is, does it matter that the ac does not work? TIA
Old Jun 12, 2016 | 03:26 PM
tamboo's Avatar
10 Year Member
Default Re: 1994 Accord Fan Problems/ overheating issues
" Low pressure switches/sensors are designed to perform two basic tasks. One is to prevent the evaporator from icing up due to a system malfunction (usually a leak). The other is to prevent the compressor from running due to a severe refrigerant undercharge which could damage the compressor."
https://honda-tech.com/tech-misc-15/...oesnt-2900177/
Old Jun 12, 2016 | 07:40 PM
Umm. So does that mean that it wouldnt come on? Not try to be a smart *** but not sure what you are telling me. I understand that my ac does not work, however I was asking if that would cause a problem with both fans not coming on like they should.
Old Jun 12, 2016 | 08:57 PM
hls90's Avatar
Under certain conditions, low ac pressure will prevent your fans from operating
geribair
Jun 7, 2014 11:18 AM
twenz
Sep 14, 2013 11:29 PM
duyfash0
Oct 8, 2008 06:46 PM
puffdaddy411
Aug 11, 2007 04:52 PM
Sherm
Sep 28, 2006 09:52 PM
