Speed Sensor Replacement
Old Jun 10, 2016 | 05:35 PM
Jimi Hondrix's Avatar
Default Speed Sensor Replacement
1997 Civic EX stock, A/T, 163k miles.
As of three days ago speedometer not working, automatic transmission shifting a bit differently than normal, slightly higher and rougher idle. CEL P0501 associated with speed sensor. Disconnected harness from speed sensor = no change.
I plan to pull one from a salvage yard and I'm wondering if it has to be pulled from an EX or can it be pulled from any 6th gen model?
Does this diagnostic procedure apply to 6th gens too: VSS - Vehicle Speed Sensor Troubleshoot, Repair, Replace - How To.
Old Jun 11, 2016 | 07:39 AM
SpeedRacerEX-R's Avatar
Default Re: Speed Sensor Replacement
1997 HONDA CIVIC 1.6L L4 Speed Sensor | RockAuto
$50. I wouldn't mess with a used one, you'll be back in the same boat.
Old Jun 11, 2016 | 08:37 AM
Unfortunately, CockAuto sells mostly after-market parts like the one's you linked.
So, then I'd end up paying 5x (or possibly 10x if it's a pocket-part..wink,wink.) as much as salvaged and still be looking for another one within 6 months..lol
Old Jun 11, 2016 | 04:07 PM
Former User's Avatar
A CEL code does not tell you specifically what is wrong. It guides you to a circuit to test. For example, did you test fuse 15?
It's time to dust off the multimeter.
Old Jun 11, 2016 | 08:21 PM
crazyhorse2011's Avatar
10 Year Member
Loved
rockauto is pretty good. ive price compared to all auto parts stores and you can always spend the same money or less for name brands vs auto parts chinese rebranded markup junk
OP go get bent
remove plug
remove 2 10mm bolts
pull out sensor
put in sensor
replace 10mm bolts
plug sensor
drive car
Old Jun 12, 2016 | 02:05 AM
Thanks Ron. I had a feeling you were going to mention fuse 15. I haven't tested yet. I did look in local salvage yards yesterday but, none to be had. I'll follow the procedure shown in replies by banned member (The bad-boy) Ron J. ..Lol.
Speedometer Not working | ClubCivic.com - Your Online Civic Community
Old Jun 12, 2016 | 02:06 AM
There's a difference between name brand such as Dorman (****), OE (Honda) and OEM (Suppliers for Honda Factory). RockAuto mostly pimps aftermarket parts and sells few OEM parts. The OEM parts they do sell are generally more expensive then suppliers like HondaPartsNow, HondaPartsNetwork Majestic and other trusted OE/OEM Honda parts suppliers.
OP go get bent
I'm not opposed to pounding a few brews while wrenching.
Old Jun 12, 2016 | 07:09 AM
https://honda-tech.com/honda-civic-d...fuses-3079359/
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
Old Jun 12, 2016 | 08:57 AM
Thanks again Ron
Old Jun 15, 2016 | 06:49 PM
Salvage yard entrance = $3
Used speed sensor = $12
Easy fix = priceless
Fortunately, found exact same year, make, model with A/T that had the speed sensor still in it. Definitely, some differences among sensors within the same generation. Some gears spin clockwise, some spin counter-clockwise, and there are gear diameter differences. The gear splines on the failed part is worn pretty badly. The splines on the used replaced part look to be in very good condition.
Old Jun 16, 2016 | 06:50 AM
oneheadlight's Avatar
soo.... did the replacement from the junkyard work for you and fix the problem??
thannon2
22
Jan 20, 2009 08:04 PM
flyinga
Oct 29, 2006 04:24 AM
rleonekc
Apr 2, 2006 06:33 AM
