Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Crank not aligned with cam help
Old Jun 8, 2016 | 05:32 PM
agarnier's Avatar
Default Crank not aligned with cam help
I'm starting my water pump job and noticed that when I align the crankpulley white mark with engine block arrow, the camshaft marks are not aligned. I was wondering if this is common. I don't want to tear down the engine and remove the timing belt if the markings on the engine are off.
I attached three pictures one of the camshaft aligned with the mark on the plastic timing cover(#1 TDC) note that the rear camshaft mark is aligned as well.
I then attached a photo of the crank white mark and engine mark being off by maybe 1/4 inch
The photos are a little deceiving because of the angle I had to take it at.
I hope I am just being paranoid!
My thought is to remove the crank pulley and plastic timing covers and check the sprockets mark with the engine block marks?
Old Jun 11, 2016 | 03:11 AM
poorman212's Avatar
Default Re: Crank not aligned with cam help
Has the belt been changed before?
The cam gears like to move when the belt is off and there is a chance that if the job was done before that they didn't get it lined up.
When doing any timing belt job, I will use something ("silver sharpie" is my favorite) and make marks on the belt to the gear(s). Then remove the belt and transfer those marks to the new belt - count the teeth between marks.
Then when the new belt goes on, the marks should line up. If not, something has moved.
Old Jun 11, 2016 | 04:24 AM
agarnier's Avatar
I just finished the job. The timing mark on the crankshaft and both cam shafts aligned on the engine. Just not on the covers. So I lined them up and also dos the sharpie trick. Car started up and ran like a charm.
Old Jun 11, 2016 | 04:25 AM
agarnier's Avatar
bluedelsol
Feb 23, 2004 02:49 PM
MaxSterling
Jul 9, 2003 06:57 PM
JohnnyEF
21
Jun 8, 2003 04:41 PM
Jonathan_ED3
Apr 12, 2003 02:55 PM
