Compression testing 2000 civic
Old Jun 7, 2016 | 03:06 PM
electronblueej8's Avatar
Default Compression testing 2000 civic
Pretty sure my head gasket is bad I am going to compression test it ( 2000, honda, civic, d16y8) I have been reading some people dont unplug the parts before the test and some do, also some say cold engine and some say warm can anyone clarify for me. Do i need to unplug the ecu or anything else
Old Jun 8, 2016 | 08:05 AM
SpeedRacerEX-R's Avatar
Default Re: Compression testing 2000 civic
Me personally, I do cold engine, unplug ecu, and throttle body at WOT.
Old Jun 8, 2016 | 10:12 AM
mk378's Avatar
Unplug the distributor is all you need to do. That will kill the spark and fuel. Not sparking is important because the coil is prone to damage from firing without the spark plug wires hooked up.
Old Jun 10, 2016 | 01:10 PM
fcm's Avatar
fcm
Old Fart
Ditto the above, kill the spark and fuel, and WOT, but do it with a warm engine and all plugs removed. 94
Old Jun 11, 2016 | 11:18 AM
superdavebigD's Avatar
This is how I do it. I think slightly warmed up is the correct way.
-Remove ALL the plugs.
-Remove PGM FI fuse (behind glove box)
-Hold throttle WIDE OPEN
-crank till tester won't go higher.
-Do all 4 cylinders the SAME WAY
Koko4
12
Jul 27, 2014 06:25 AM
jdm_sai
18
Feb 16, 2010 05:19 AM
95teg_ls
Apr 21, 2008 08:42 AM
fakeownzjoo
Sep 21, 2006 04:31 PM
mrkflow
Jun 20, 2006 10:10 PM
