Radiator fan won't turn on
Old Jun 1, 2016 | 08:44 PM
Mitchell A.'s Avatar
Default Radiator fan won't turn on
How did this get resolved, i have the same problem. Relay is okay, fan works when powered directly or when I bypass the fan switch. I replaced the fan switch with a new one. The fan still does not engage and the car overheats after idling for 20 minutes. Did I buy a bad fan switch or is there something else I should try?
Old Jun 2, 2016 | 07:23 AM
mk378's Avatar
Default Re: 97 civic ex - thermostat fan switch
Check the pins in the switch and the plug and replace if bent or broken. The switch can be tested off the car by putting it in a shallow pan of water and heating the water on a stove. The switch should click and show continuity at 160 F.
Old Jun 3, 2016 | 02:00 PM
I tested the new and old fan switch in boiling water they both closed and had continuity. i was hoping they were no good. What's next?
Old Jun 3, 2016 | 02:08 PM
Former User's Avatar
BLEED
Edit the first post by adding car information.
Old Jun 5, 2016 | 01:21 PM
Default Re: Radiator fan won't turn on
Thanks Guys. MK378 you were right. I tested the switch on my stove and it worked perfectly. I tested on the car and it also worked. When I put the plug back on the fan came on for just a second. When I pressed on the plug the fan stayed on. i went to the salvage yard got a plug to replace mine. Problem solved.
Old Jun 5, 2016 | 02:16 PM
K20A3F00L's Avatar
Always love a happy ending :D
kirkland08
Mar 5, 2011 01:15 PM
tonysaur
Nov 17, 2007 11:39 AM
ATS*Mark
Dec 9, 2003 11:08 PM
HybridKOOP
Aug 14, 2002 11:08 AM
