rods and pistons don't match up
Old Jun 1, 2016 | 12:56 PM
Type 56's Avatar
Default rods and pistons don't match up
as you can see there's barely any slack for the rod to maneuver around while connected to the piston. so the question is what should i do next to addressed this problem? should return the pistons and get an oem spec one, or should i order the correct spec rods that would fit the CTR pistons? then there's the other option where i could just order a new sets of rods and just shave it down enough to have clearance. i'm not even sure if the last option is a viable option or not. i need guidance! and sorry for the oversize pic. i don't know how to thumbnail these pics on this site yet.
Old Jun 1, 2016 | 01:19 PM
Pro-SeriesFab's Avatar
Default Re: rods and pistons don't match up
Find a friend with a surface grinder or vertical mill . . . surface grinder if you really care what the surface finish is or vertical mill if you don't. All you really need is a little more clearance.
Just make sure whoever is cutting them weight matches the set with however much they take off of each one.
Old Jun 1, 2016 | 01:34 PM
1HGEJ2's Avatar
young geezer
Oct 13, 2010 01:16 PM
lsvtec2000
Feb 6, 2009 07:08 AM
veilsides2000
Jul 25, 2005 06:44 PM
StupidSlowRSX
Jan 27, 2005 08:37 PM
vtec69
Jun 17, 2002 09:28 AM
