Front passenger door leaking
My 1998 Honda Civic LX was broke into a couple months ago and they had shoved something down the passenger front window and bent chrome trim out along with the door a little bit and now when it rains the water runs down the window and is leaking into my car. There's a good-sized gap between the glass and the door now. How would I go about fixing the leak since the weatherstrip is also bent out with the trim and doesn't fit up flush with the window?
My 93 eg was missing the weather strip so I went to the car parts yard and found some a similar generation weather strip and snapped it in. It's a very easy thing to put in.
But even when it was missing, I don't recall if water ever leaked into my vehicle since I fixed it before it ever rained.
Just did my pass front door on my 94 RS, found a "molding assembly", [that's what Honda calls it] removed the glass, and inside door trim panel, unclipped the old molding, and with it out from the outside around the middle of the door on top I gave it a little push as it was bowed out a little, once straight I installed the new, [to me] molding, no more leaking into the door, 94
zx92027xz
Sep 9, 2010 04:35 PM
Kataku2K3
Feb 11, 2007 02:06 PM
WindyIce
11
Mar 1, 2004 10:57 AM
