Obd2a d16y8 5 speed conversion into 99 ex
I have a 99 Ex (d16y8 auto) and the trans went out. I have a motor/5spd trans from a 96 ex. Ive done all my research on the swap, and have just one question left as far as compatibility.
My plan is keep the obd2b harness, and swap over the obd2b dizzy to the 96 motor. I have a 99 5spd ecu (p2p a12). Will this work or am I missing something with the compatibility of these two? Thanks!
You probably never removed an auto transmission before but I see where you're going with this. You planned to do the 5spd conversoin but decided to swap out the entire thing.
Yes it should work.
Yes it should work.
For someone so confident in others abilities,"yes it should work" seems lackluster.
It doesn't have to be "all out" to do a 5spd swap. That is what I'm referring to. if you've done this before than you don't need to have it all out just to replace the transmission. i could give you another option but you seem to be set on putting it in, so have at it.
