H2B high end header / test pipe
Old May 28, 2016 | 10:15 PM
3rdtimecharmer's Avatar
10 Year Member
Default H2B high end header / test pipe
Hello all,
Hit a wall in build. 1994 acura integra GSR, F20b/itr trans.
I have the high end header and purchased a 2.5 in test pipe.
The test pipe bolt flanges do not line up. I thought the high end header collectorsize is 2.5?why is the flange on collector side smaller?
Any help appreciated.
Old May 30, 2016 | 09:54 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: H2B high end header / test pipe
Do you have any measurements for this? I will have to check mine tomorrow.
Old May 31, 2016 | 07:53 AM
10 Year Member
i do not have exact measurements, I can check after work.
I hit this wall and cannot find a definite answer.
the high end header states "true 2.5 in" collector and the test pipe as well.
but the flanges are different sizes, the flange on the test pipe end is bigger so the holes do not line up with the flange on the collector side.
I ordered a 2.5 inch donut flange kit thinking maybe the test pipe just has the wrong size flange BUT its the same... holes wont line up due to bigger flange on the test pipe side.
Old Jul 12, 2016 | 07:02 AM
10 Year Member
Damn noone? I'm still stuck. I just keep buying diff flanges and getting discouraged .. Haven't touch the car since then.
Bseries91si
May 28, 2015 06:53 PM
the soL that could
Mar 14, 2006 09:12 AM
Tippyman
Dec 21, 2005 07:30 PM
-Whitey-
Jan 27, 2003 11:58 AM
