Turbo Kit
Old Nov 7, 2002 | 02:25 PM
NaSh123's Avatar
Default Turbo Kit
hey i have a 99 ex civic with a d16y8 engine the ONLY turbo kit i was able to find was the drag gen 3 for about 3000 i was wondering if there are any other ones that would fit my car thanks, also if anyone has expierence with drag gen 3 exactly how good is it
Old Nov 7, 2002 | 02:39 PM
Matt B's Avatar
Default Re: Turbo Kit (NaSh123)
the Greddy kit for 92-95 civics will work.
Old Nov 7, 2002 | 02:41 PM
Jin Yamato's Avatar
Default Re: Turbo Kit (Matt B)
Don't turbo that motor.
Swap instead of turbo.
Trust me, it's much better.
A d-series is not a powerful motor.
Swap a b16a and turbo that.
Old Nov 7, 2002 | 02:50 PM
NaSh123's Avatar
the greddy 92-95 will work on a 99 civic? aren't the engines and setup different tho?
Old Nov 7, 2002 | 02:51 PM
NaSh123's Avatar
Default Re: Turbo Kit (jin_)
how much would it be approx to get b16 engine install and any site that i can look at that?
Old Nov 7, 2002 | 02:52 PM
Jin Yamato's Avatar
http://www.osakajdmmotors.com/
Cheap.
Edit for fixed link
[Modified by jin_, 3:52 PM 11/7/2002]
Old Nov 7, 2002 | 02:56 PM
Ricey McRicerton's Avatar
I dont agree with the swap theory...think about this...you can find that Greddy turbo kit for 1500 bucks, and then you can walk on a car with just a B16 swap. And youll have some torque!!! I just cant imagine that the B16 is much better than my turbo y7
Old Nov 7, 2002 | 03:08 PM
Kamin's Avatar
Default Re: Turbo Kit (Ricey McRicerton)
1500$?
you aint gonna find a greddy kit for 1500$
if you do, its not gonna make enough power to "walk a b16"
and for 3000$ you could get a b18c and have torque.
Jin Yamato's Avatar
I didn't say that the b16 was better.
It makes more sense to swap a b16 and save money to turbo that than turbo a stock d-series.
Just my $.02
Old Nov 7, 2002 | 03:39 PM
Matt B's Avatar
http://www.turbocivic.net/
Old Nov 7, 2002 | 07:15 PM
Hammett's Avatar
For a basic greddy kit = $1500 shipped or even cheaper
but you also need BOV, Intercooler, injectors, clutch + more and more to run higher boost. How much money r you gonna spend?
Old Nov 7, 2002 | 07:57 PM
99sohcturbo's Avatar
The drag kit is pretty good, except for a few things. They come with in in-line fuel pump in which the directions say to install in the engine compartment after the fuel filter. Big no-no, if something were to happen (which it has and drag has been sued on it) like the fuel pump lines leaking, 1 spark can set your car on fire and there would be nothing you could do but watch it burn. It almost happened to me and i've heard of it happenening to others. You'd want to get a walboro 255lph in-tank fuel pump, You'll be much better off. It costs about $100. Another thing I didnt like about the drag kit is the directions. They are VERY basic and are meant for professional mechanics. I am not a professional mechanic but i have mechanic experience because I work on aircraft in the military. This install took me just about 4 days because of lack of directions, and missing parts from the kit. I hear Greddy kits come with great instructions and just about everything you'd need for a good install.
Old Nov 7, 2002 | 08:05 PM
You wont save that much money doing a swap. Chances are you'll probably spend more money. A complete b16a2 (99-00 si) with hydro tranny and all the goodies will run for $2500+ from any reputable company. Then you need motor mounts $500, change all belts/gaskets/fluids another $100+. Or you can settle for some jdm motor which they claim less than 30k which was beat the hell up. Plus you dont even know how much actual mileage it has because they dont come with an odometer. I've heard horror stories about jdm engines coming in all banged up, seized, etc. With my drag gen III on my d16y8 engine 6lbs of boost (for right now until i get my in-tank fuel pump and better injectors) i can walk on any stock b16 swap. If your talking a b16 with turbo then your gonna be looking at a nice $6k+.
Old Nov 7, 2002 | 08:20 PM
SuperRice's Avatar
Well the way I see it is how much more money are you willing to spend on your car. For example, I also have a D16Y8 and I'm going turbo because I don't plan on spending more than $2000 on my car I have student loans to payoff soon. I just figured with my budget I would gain most with the turbo. But if you have a lot of cash to burn, definitely get a swap and then build on that.
Old Nov 7, 2002 | 10:30 PM
Bleed Black's Avatar
Default Re: Turbo Kit (SuperRice)
Greddy turbo kit=$1450 all day long. Non intercooled it will walk a B16 with ease. Why does this swap BS pop up in everythread. He didnt ask if he should swap or not .
But Greddy, Apex-i, Drag III, And I believe Rev-Hard all make turbo kits for your motor. As long as its for a D16 it'll work.
Old Nov 8, 2002 | 02:22 AM
D16Z6racing's Avatar
Shame on you! You've underestimated the power of D series. D16 VTEC w/ GReddy turbo, would beat a Civic B16 swap.
Old Nov 8, 2002 | 05:30 AM
DUCK COMMANDER's Avatar
Default Re: Turbo Kit (buster13)
yeah the turboed singlecam will whoop up on a b16 powered civic with minor mods. greddy kit new 1450..get it used for 1100, starion intercooler 150, mod piping 50. BOV 150..bam...low to mid 14 second times on street tires. I know..i did it with a clutch so bad i had to let off 5 times in the quarter to let the clutch catch up with the motor..
plus...d16 longblocks are 2-300 bux
Old Nov 8, 2002 | 08:21 AM
Default Re: Turbo Kit (JSutterEH2)
Exactly. Plenty of room for error
Old Nov 8, 2002 | 11:47 AM
Default Re: Turbo Kit (slowasshatch)
right..plenty of room for error...which means that it is PERFECT for a 1st kit or something. I know of countless times when some boy has turboed his 2001 GSR ans blew it up running 12 lbs on a stock drag kit. Blow up a couble single cams. then buy the badass setup down the road. Thast what i am doing (thought my single cam didn't blow up)
I did run about 12 lbs the ist night i had it(no boost guage) Felt strong as hell lol. I would just punch it in 2nd ans it would light them up like hell
Old Nov 14, 2002 | 04:56 AM
I can get Drag kits complete for $2700. Turbonetics turbo, intercooler, Chrome intercooler piping, Blitz DD BOV, deltagate, Vorthech FMU etc. If anyone is interested let me know and I can get em for most apps, price might vary. $2700 for a drag kit you cant lose.
Old Nov 14, 2002 | 05:03 AM
brcivic411's Avatar
Default Re: Turbo Kit (99sohcturbo)
92-95 Greddy turbo kit on a d16y8
Old Nov 14, 2002 | 06:55 AM
oldskool_rex's Avatar
Very good thinking...but beware, once you boost, you can't go back
All motor is great. I love it. But face it.......Turbo looks better, soundsbetter, runs better, and it is still faster! (of course, this is a generalization. We all know of an all motor car car beat a turbo car depending on the setups. Basically, bang for the buck is better with boost)
mpxs20
Jun 20, 2005 07:08 PM
97exd16
Jun 8, 2005 11:11 PM
bad93ex
Feb 15, 2003 02:34 PM
halo5
Apr 18, 2002 02:45 AM
dragonsmp
May 23, 2001 05:38 AM
