00 Civic - temp gauge reads low and fluctuates
Old May 28, 2016 | 09:21 AM
electronblueej8's Avatar
Default 00 Civic - temp gauge reads low and fluctuates
I have a 2000 honda civic d16y8 I changed the themostat and now my temperature gauge seems very low and fluctuating a little does that seem normal or could my (fail safe) themostat be stuck open?
Old May 28, 2016 | 09:23 AM
Former User's Avatar
Default re: 00 Civic - temp gauge reads low and fluctuates
https://honda-tech.com/honda-civic-d.../#post39830585
Old May 28, 2016 | 10:31 AM
Thanks for the quick response, Ill try it later to after work and let you know
Old May 29, 2016 | 07:48 AM
Default Re: 00 Civic - temp gauge reads low and fluctuates
Okay so while bleeding the cooling system and waiting for my fan to kick on it didnt so I wired my thermo switch and my fan did run continuous. So I ordered oem thermo switch
Old May 29, 2016 | 08:34 AM
Describe how you bled and for how long. The switch only turns on the fan when the coolant reaches a threshold temperature. That's why the switch was designed into the system.
Old May 31, 2016 | 01:45 PM
After putting the front on an incline I loosened the radiator car and started the car but after waiting apporomently 20 minutes my engine was crazy hot but my fan never came on
Old Jun 1, 2016 | 07:51 PM
You need keep the radiator and reservoir topped off with coolant during the entire bleed procedure.
Old Jun 3, 2016 | 06:50 PM
Okay will do, but my fan still be turning on right?
Old Jun 4, 2016 | 06:35 AM
DumpdEJ6's Avatar
I like the tuna here
Eventually, but you might be surprised how long it can take with the engine just idling. I like to move the throttle up to about 1.5k to get the engine hot quicker, otherwise it can take like 20 minutes or so. Even though the car isn't moving, heat is still dissipating through the fins of the radiator.
Old Jun 4, 2016 | 08:08 AM
Did you following the bleed instructions to the tee? For example, the cabin heater must be set to maximum heat.
Old Jun 5, 2016 | 07:02 AM
I didnt throttle it any, but my iacv and themroswitch should be here today i know my iacv bad so my cars idling at 1-1.5 the reason i ordered the thermoswitch is when i pulled the plug coolant was in it so im guessing the o-ring on the plug went bad? Also u going to hday your cars clean im in concord
Old Jun 5, 2016 | 07:03 AM
Yes I read it a few times before doing it I did have my heater to max
Jamie Steadman
Aug 14, 2015 12:07 PM
PunkRudeBoy
10
Jun 28, 2011 08:45 PM
yosuoh
Jun 18, 2011 08:52 AM
landon.alder
Sep 16, 2010 02:30 PM
Shade93
Apr 13, 2010 01:15 PM
