2010 honda accord tail light
Do you have a volt meter to take some readings?
LT GRN should have battery voltage when the brake is pressed. The BLK should have good continuity to ground....I'll assume it does since I believe the outer brake lights both share this ground point but test it anyway.
Having the exact same problem with my 2010 Crosstour. Checked power and got 8 vdc with the meter. Had the AC condensor changed recently. when I picked up my car I noticed that the programming for driver seat and mirrors was not set when I got home.
Status
Jun 19, 2006 08:52 AM
Suke
Nov 9, 2004 09:53 PM
