99 civic ex help... wont start
i move from the west coast to the midwest. i storage my civic during winter (snow)...
decided to take it out.. parked in the backyard and let it idle... been idle for 2, 3 hour (not sure how long) while i do other things. later it shut off... 30-40min (cant remeber) before it shut off i check on the temp it wasn't hot.
now it wont start... i thought it was gasoline even thought it show half tank, went and got some more... still wont start.... it does turn over so it not starter... i did compression test.. all 4 cylinder is 150psi no leak... change out dizzy(complete new one), yes there spark.... also change out spark plug, spark plug wire, fuel filter, main relay. i dont think it the fuel pump cuz i can hear it rushing to the front (turning key). i dont think it the fuel injector cuz when i took out the new spark plug it was wet with gasoline... im thinking ECU? also timing belt didnt snap... maybe timing jump a tooth?
any help... thank.
any help... thank.
Check for spark and CEL codes.
https://honda-tech.com/honda-civic-d...blems-2919450/
https://honda-tech.com/honda-civic-d...lists-1901557/
Do you hear the fuel pump prime?
davidzhou4893
10
Mar 18, 2014 08:53 AM
infinkc
Feb 21, 2013 01:32 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
streetjdmrex
Aug 8, 2007 12:59 AM
