1997 Civic H22a1 swap project
Old May 26, 2016 | 03:36 AM
MattMcCrossfit's Avatar
Default 1997 Civic H22a1 swap project
So over the years I have searched these boards so i'm not really new, but thought i'd show you guys what i've been up to, and my current project.
97' Civic EX d16y8.. Ended up turbo charging it, with an Egay kit (i know), it actually drove fine for 12k miles until it finally exploded #3 rod. No tune, just basemap, my ignorance.. fun while it lasted. here are some pictures of that, along with what i'm up to now.
Here she is after turbo install.
kaboom
got this motor from the hills of kentucky for $500. miles unsure, but compression is good and oil was clean.
New clutch while it's easily accessible. old clutch didn't look bad
clean up the trans a bit and it's back bolted to the block. going to do the timing belt and manual tensioner swap, along with some other gaskets and such before the install. using Innovative engine mounts, and yonaka swap axles, and an accord shifter box, linkages. P28 OBD1 chipped ECU, and custom making my own wiring harness since stock harness is OBD2, so using a conversion harnes into the ECU, and swapping plugs to OBD1 (pain in the *** i know).
These are the OBD1 plugs to swap into the stock harness
external coil headache
new custom harness on the right.. old hacked up harness on the left.
Motor is in! Just bolted up to the mounts for now, leaving for the weekend on vacation, will finish up when I get back next week.
MattMcCrossfit
May 20, 2016 05:59 AM
shutuprichard551
26
Aug 14, 2009 07:11 PM
newt_719
Apr 8, 2009 10:35 AM
HILLBILLY75169
Mar 16, 2008 10:46 AM
Nickblaskowski27
Jul 28, 2005 10:08 PM
