over heats than boost cuts
so my ls vtec turbo runs great until the engine light comes on and it starts to over heat and the boost cuts off. i am running s300 with arm wide band. i haven't had the chance to run the code yet but want to know if anyone else had that problem, over heating and boost cutting off? Second part of the question is when it over heats i turn the heater on and the temperature drops back down. is that bad thermostat ? thanks in advance
so my ls vtec turbo runs great until the engine light comes on and it starts to over heat and the boost cuts off. i haven't had the chance to run the code yet but want to know if anyone else had that problem, over heating and boost cutting off? Second part of the question is when it over heats i turn the heater on and the temperature drops back down. is that bad thermostat ? thanks in advance
