6262 b16 32psi 550whp pump gas timing help
Hallo from Greece
I have a b16 95 pump gas 32psi 6262 gen1 with gsr cams with around 14deg at 9000rpm and 11.2 afr and it makes 550whp at DynoJet
The timing starts around 6deg at 5000rpm and I increase it until 14 at redline. Is it too low? Any big turbo guys can you post any timing maps please?
Thanks
Thanks
every engine is different. even identical builds will have different ignition.
on pump gas, there's definitely no generic range that's right or wrong.
that's what it was tuned for, that's what it needs. if you're having issues, check your spark plugs.
Black R
Mar 4, 2014 05:54 AM
