92 civic hatch build
Old May 24, 2016 | 10:58 AM
Afrasier1650's Avatar
Default 92 civic hatch build
So I was looking into buying a civic hatch 92 and wasn't too sure on what all the motor terms were it's a b20 403 crower cam? https://akroncanton.craigslist.org/cto/5562114223.html
This is the car and was looking to buy but needed some help on specifications and more of an understanding/ what to look for when buying it thanks guys!!!
Old May 24, 2016 | 12:26 PM
Ohmega's Avatar
Default Re: 92 civic hatch build
Not sure if this is the correct location for this post, but regardless, a b20 is a dual cam, MPFI, 2 liter engine. I believe it was found in Honda CRV's exclusively, but don't quote me on that.
If you're buying from CL i highly suggest asking the owner to remove the valve cover and send pictures of the modifications done to the valvetrain. Seeing inside the engine can also give you a VERY general sense of how the engine was maintained.
Start there and report back with pictures.
Old May 24, 2016 | 12:29 PM
Ohmega's Avatar
A few side notes:
I doubt this owner has all the COMPLETE interior, expect a few pieces to be missing.
He has a speaker with on his dash=no radio
I spy cheap ebay parts, beware
Old May 24, 2016 | 12:48 PM
DooDooBrownEg's Avatar
Or just double check the compression, my bet is a crower cam will change that. Double check standard compression for a b20, then do a test on the cl motor. If improved compression, then it more than likely will have one. Also, is there only just a cam installed? Why put a new shoelace on a shoe without updating the sole and tread and inserts? See what I did there?
Old May 24, 2016 | 12:52 PM
Ohmega's Avatar
Riddle me this Batman: How does a cam change compression?
Old May 24, 2016 | 12:55 PM
How do cams affect compression?
That should help.
Rav
Dec 26, 2007 09:59 PM
TeggerLS
Sep 13, 2006 04:44 PM
jrflip
Aug 4, 2006 04:00 PM
OneQuickNA
Mar 23, 2004 10:06 AM
thejdmkid
Apr 18, 2002 10:26 AM
