2007 Accord Main relay 2
Instructions on my fuel injection cleaning system (OTC) says to "Remove PGM-FI Relay 2 at LH side of dash" to disable fuel pump during cleaning process. I've searched relentlessly and so far can't locate it. I've found what I believe is the Main Relay, but no go on "#2". I did find a Fuel Pump fuse (15amp) but removing it also disables the ignition.
Any thoughts much appreciated
Larry
Larry
Found it. Thanks Tech8 it was right where you said. There was no access panel for the relays. Caught a glimpse of them up above the fuse panel and had to remove the kick panel to access it. Mission accomplished - injectors cleaned.
Thanks again
Thanks again
deadhead23
Jan 15, 2021 10:43 AM
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
uneekcrx
Apr 11, 2002 06:59 PM
