A friend recommended that i....
Old Nov 7, 2002 | 01:26 PM
Alias's Avatar
Default A friend recommended that i....
Take off my header, pull my spark plug wires, and remove my fuel pump fuse. Then crank the engine. My friend said that it will remove alot of the gunk that bulds up within the engine. I was wondering if anybody has done this?
Old Nov 7, 2002 | 01:27 PM
Gennady's Avatar
New User
Default Re: A friend recommended that i.... (Alias)
How would it do that?
Old Nov 7, 2002 | 01:29 PM
Alias's Avatar
Default Re: A friend recommended that i.... (Wont be beat)
no idea, that what he said it would do.
Old Nov 7, 2002 | 01:32 PM
niedejb's Avatar
I would not call him a friend any longer.
This will do nothing for you.
Accord94DX's Avatar
i give you permission to kick your friend in the nuts.
Old Nov 7, 2002 | 01:34 PM
Gennady's Avatar
New User
If you loosen one lug nut on the right front wheel to 15.4 ft lbs. of torque, leave the rear left window rolled down, stand on one leg and enduce projective vomiting, you can safely rev to 8000rpm.
Old Nov 7, 2002 | 01:36 PM
Desslok's Avatar
Only while balancing on one foot and rubbing your head and tapping your stomach at the same time.
Old Nov 7, 2002 | 01:43 PM
iam7head's Avatar
Default Re: A friend recommended that i.... (sp)
yep..you can smack your fd's face now..go go..
Old Nov 7, 2002 | 02:06 PM
Old Skool's Avatar
here's some more stuff you can try, but you have to do it in a very specific order:
1. open hood
2. check blinkerfluid (resivoir located under the quadrajet injectorator)
3. make sure your mufflerbearing has a green-ion tint (that means its spinning right)
4. turn the flux-capacitor to setting 11, not 10 - 11.
5. get in and pump the e-brake 8 or 9 times while holding in the manual choke button
after completing all these steps in the correct order you should be set to go
glad i could help
[Modified by Foomanshu, 11:07 PM 11/7/2002]
Old Nov 7, 2002 | 03:46 PM
accordfreak's Avatar
Default Re: A friend recommended that i.... ( Foomanshu)
don't forget to click your heels 3 times.
Old Nov 7, 2002 | 04:37 PM
Gennady's Avatar
New User
Default Re: A friend recommended that i.... (accordfreak)
...and pray for mercy.
Old Nov 7, 2002 | 07:40 PM
Alias's Avatar
lol ok forget everything i said before. I have learned my lesson
Old Nov 7, 2002 | 07:43 PM
PissAnt's Avatar
Much better and eaiser, just get some cheap fuel system cleaner and run it through. It can help, and if it doesn't you are out $2 and didn't break your knuckles taking your header off.
almostjdmeg
Oct 12, 2010 06:38 AM
thekid_12
Mar 25, 2008 03:31 AM
SJP0tato
Oct 4, 2004 12:17 PM
JDM_ITR
Sep 11, 2002 09:12 AM
Teal95Coupe
Nov 28, 2001 10:19 PM
