93 Del Sol - A/C Killing Engine (solved)
Old May 21, 2016 | 11:16 AM
Delcbbr's Avatar
Default 93 Del Sol - A/C Killing Engine (solved)
1993 Honda Del Sol 1.5 L. No CEL. Idles fine without the A/C. Check it out and please tell me WTH - Thanks!
Internet Postings - brberrys
Old May 21, 2016 | 11:28 AM
Former User's Avatar
Default re: 93 Del Sol - A/C Killing Engine (solved)
R12 or R134a?
Did you add refrigerant to the system?
What was the ambient temp and idle speed when pressure reading were taken?
Was the condenser fan running?
Old May 21, 2016 | 11:44 AM
Delcbbr's Avatar
R12 or R134a? 134
Did you add refrigerant to the system? Nope, but the pressure seems high
What was the ambient temp and idle speed when pressure reading were taken? Around 90f
Was the condenser fan running? Yes
Old May 21, 2016 | 11:48 AM
While spraying the condenser with cold water from a garden hose, how do the high and low pressure readings change with the engine held at 1500 rpm idle speed and A/C running on recirc and MAX blower speed?
Old May 21, 2016 | 12:20 PM
Delcbbr's Avatar
High pressure drops to 180 and the low to the mid 20's. I thought that the fan was running before, but it didn't come on while I was running the water.
Old May 21, 2016 | 12:21 PM
^That's the problem.
Fix the fan and then go from there.
Old May 21, 2016 | 01:48 PM
Delcbbr's Avatar
Yep, it was the fan. All working great now - Thanks!
Chandler Strom
Jan 19, 2016 04:22 PM
jdmwojo
22
Jun 2, 2011 10:28 AM
delsol92
Apr 27, 2011 08:31 PM
sknoslo
Sep 19, 2008 01:17 AM
almostjdmeg
Jul 30, 2008 05:52 PM
