93 Del Sol - A/C Killing Engine (solved)
1993 Honda Del Sol 1.5 L. No CEL. Idles fine without the A/C. Check it out and please tell me WTH - Thanks!
Internet Postings - brberrys
re: 93 Del Sol - A/C Killing Engine (solved)
R12 or R134a?
Did you add refrigerant to the system?
What was the ambient temp and idle speed when pressure reading were taken?
Was the condenser fan running?
R12 or R134a? 134
Did you add refrigerant to the system? Nope, but the pressure seems high
What was the ambient temp and idle speed when pressure reading were taken? Around 90f
Was the condenser fan running? Yes
While spraying the condenser with cold water from a garden hose, how do the high and low pressure readings change with the engine held at 1500 rpm idle speed and A/C running on recirc and MAX blower speed?
High pressure drops to 180 and the low to the mid 20's. I thought that the fan was running before, but it didn't come on while I was running the water.
Chandler Strom
01-19-2016 04:22 PM
delsol92
04-27-2011 08:31 PM
almostjdmeg
07-30-2008 05:52 PM
