98 Civic Lx Auto Trans - Higher Rpm's After Replacing Head Gasket
Old May 16, 2016 | 09:01 PM
Austin Brown's Avatar
Default 98 Civic Lx Auto Trans - Higher Rpm's After Replacing Head Gasket
I have a 98 Civic Lx Auto Trans and I replaced my head gasket a few days ago.
I do alot of highway driving and I noticed that to maintain a speed of 60 I need to hold it at a higher rpm than before. Before it was ~2.2k to maintain 60 but now it is ~2.9k. After the head gasket fix the idle was high( over 2k) because of a vacuum leak between the intake manifold and the head. I tightened the bolts more (my torque wrench couldn't fit to tighten the bolts) and the idle rpm dropped significantly. Could it be a leak still?
Also the gasket set that i bought came with 2 different intake manifold gaskets. I only put 1 on.
Old May 17, 2016 | 08:27 AM
tony_2018's Avatar
Fish Twig
Default Re: 98 Civic Lx Auto Trans - Higher Rpm's After Replacing Head Gasket
lock up is not occuring..
Old May 17, 2016 | 10:09 AM
If that was going on wouldn't I have some sort of CEL?
Old May 17, 2016 | 12:42 PM
chrysler kid's Avatar
Are you sure the car is shifting into overdrive? A trans problem would be indicated by the grear selector icon flashing on the dash
Old May 17, 2016 | 01:20 PM
mk378's Avatar
Did you unplug the trans solenoids during the job? If so you need to make sure they are replugged correctly. Also, misadjusting the throttle cable to the trans can make it think you have the gas floored all the time and stay in "kick down" to a lower gear, but that would probably make the rpm much higher.
Old May 17, 2016 | 04:11 PM
I didn't unplug it. Some coolant was spilled on it so maybe that could have done something?
Old May 17, 2016 | 04:13 PM
Gear selector icon is not flashing. And I don't think I have overdrive, but i may be wrong.
Old May 17, 2016 | 04:44 PM
Fourth gear is considered overdrive
Old May 17, 2016 | 05:03 PM
I'm definitely getting into 4th
Old May 17, 2016 | 07:04 PM
tony_2018's Avatar
Fish Twig
Its only 4 gears in an auto for this specific yr.
Overdrive would be 3rd gear.
Reset ecu and relearn idle.
Old May 18, 2016 | 04:24 AM
Really? Damn haha I've only owned manuals
thekid2390
Jul 21, 2013 12:50 AM
Brandon92
Oct 11, 2011 08:51 PM
hybrid90
19
Jun 23, 2011 05:03 AM
kja5070
Mar 28, 2009 06:49 PM
hondamoonchucks
Aug 1, 2006 09:21 PM
