Race car / wana be sfwd part out. 760hp+. All new parts recently
race car / wana be sfwd part out. tons of my car after a terrible accident
I'm going to try my best to list parts. And then eventually list pricing. will update this ad throughout the next 24 hours
For the most part I would prefer local pick up here in Baltimore md 21222 where I live. Not sure I have the time or availability to run to shipping stores daily with large parts nor do I have the boxes tape etc
Car was my pride and joy. And use to be the charm city tuning 67mm record holder
The cage saved my life. Not sure what happened at the accident because I don't remember it. But now I'm ready to sell it all and move on
Pleas look through pics Cars accident was most rear end damage and rear driver side with some driver door damage. There is no damage to engine or any engine parts The Front ends bumper and fender are destroyed so the front end is not for sale , seats are damaged and steering wheel is damaged other then that most everything I list below is up for grabs
A lot of this stuff has less then 5000 miles. Car was just built December of 2015 till now
Thanks for interest and looking here's the list :
-edelbrock victor x intake manifold. For gsr head. Perfect shape with custom powder coat. 65mm throttle body , Hondata 4 bar map sensor with newer tps as well. Also has idle air control valve etc will come with hondata intake manifold gasket and throttle body gasket 375$ complete setup ready to go (will separate stuff if you want stuff separated for the right price ) I have 200$ alone in powder coat on the manifold plus 100$ for map sensor plus price for the other stuff itself. Seems like a deal to me
-real oem Jdm itr type r cams perfect shape with skunk 2 tuner series cam gears. Mint cams perfect shape made 760+hp with these cams (Will separate gears off cams and sell separate for the right price ). - SOLD
-gsr cylinder head off the lsvtec engine out of the car. Ferrea 6000 complete valve set just recently put in with a 5 angle valve job by machine shop in Baltimore md super tech turbo valve train 85lb m just recently bought and installed as well. Supertech valve stem seals just put in . Skunk 2 Lost motion assemblies Complete running perfect head. Made 760+hp with it. No cams or cam gears included. No dizzy included and will come with stock red painted valve cover Will have speed factory titanium hardware for exhaust . And come with vtec solenoid and all sensors bolts etc . Cams are listed above for sale. And no dizzy because I had coil on plug which is listed below for sale as well -650$
(I have 800$ alone in valve train purchase valve job by machine shop and install. )
-Sheepey top mount turbo manifold t4 divided twin 44mm gate flanges -Sold
-44mm tial gates I have 2 with all springs bolts etc. silver in colors -sold
- Sheepey 4" up pipe tear drop. Will come with trim ring and flange clamp it is the marmon flange with trim plate and clamp for flange-sold
- Borg Warner s366sxe turbo super core billet wheel with .91 t4 divided exhaust housing with marmon flange. With black turbo blanket. Like new maybe 1000 miles have reciept I purchased new . -750$ with turbo blanket
-Intercooler (need to measure size ) custom made garret core 800+. -SOLD
-Dumptubes -SOLD
-Hondata boost controller 3 port hondata brand with push lok hose and fittings 80$
-alum half size Radiator mishimoto brand with mishimoto slim fan and cooling fan plate with a custom chase bays reservoir with black paint with push lock line and fittings and custom water neck on radiator for clearance of up pipe -280$ for everything
-Intercooler piping with 50mm tial flange and couplings and clamps -SOLD
-ati street damper pulley with power steering pulley only 1000 miles i bought brand new for 330$ on sale. - SOLD
-Id injector dynamics 2000cc injectors for bseries. Less then 1000 miles. Only e85 ran in them like new have box and stickers and everything - SOLD
-Blow off valve custom powder coat tial 50mm- SOLD
-Catch can t1 setup with all 6 lines and fittings and also the valve cover. Selling this as a complete set everything you need -SOLD
-Jdm type r trans. 4.4 final 96-97 spec with speed factory shift selector (450$) trans is 100% perfect not a issue. Maybe 40k miles if that can include. Vss and starter and bolts if need be for extra - sold
-oem alternator obd2. Have 2 of these
-oem starter have 2 of these
-oem speed sensor have 3 of these
-Comp clutch triple disc clutch with throwout bearing and bolts. Maybe 1,000 miles if that-SOLD
-Avid engine mounts with driver side avid bracket: Can Include trans mount bracket. Post mount bracket off engine. And t bracket. T bracket is a eg because car had eg subframe custom powder coat on brackets -400$ for all bracket and bolts and mounts. Or just mount kit 240$ with 3 mounts and driver bracket
-Blox traction bar -175$ complete kit used
Good shape not seized up comes with everything all hardware
-Stainless steel braided clutch line kit with brand new oem clutch master cylinder and res -150$
-Wilwood brake resevoir with chase bays plate Eliminates brake boost and is manual brake setup -140$
-Prop valve off 2000 si -50$
-Hondata s300 v3 in p28 ecu with bbg -SOLD
-Hondata cpr coil on plug setup. Just bought a few days ago brand new only on the car for the dyno I Bought Brand new hondata cpr kit. Brand new oem type s coils. 4130 mounting plate for bseries vtec and lo cash dizzy cover in black
-650$.
(This setup new for everything was +800$ almost 900)
**Rims and tires are SOLD! All are SOLD none are available
-Blox drags. Fronts look to be in ok shape have to check rears fronts only -sold.
rears -??( have to check condition )
-Window net and cage brackets - sold
-Bseries Axles have some Honda ones and some auto store ones 100$ for each pair
-oem Honda power mirrors fresh si blue. 100$ set
-Bseries linkage. Skunk 2 dual bend shifter and skunk 2 weighted ****. Dimes perf. Solid bushings . -150$
- Nrg quick release setup all black. Everything but a steering wheel. So I have The black nrg hub for 96-00 civic and The quick release for the steering wheel in black and carbon fiber ring but no wheel itself -200$
-99-00 si engine harness -150$ ( I have 3 of these )
-Auto meter boost gauge silver with blue light 50$ with push lok line and both push lok fittings
-Ntk ngk Wideband kit used 180$
one of best wide bands on market
-Aem oil pressure gauge kit used - SOLD
-99-00 civic si gauge cluster - sold
-Auto meter shift light with digital tach level 2 150$
-CNC staging brake 130$. Just the Brake and one single stainless line with A T- nothing else Can ad custom Made mounting bracket for 40$ extra
***Fuel system : all bought brand new by me less then 1000 miles -
Full blown dual pump hanger for civic - SOLD
Full blown fuel filter purple -10 each side
Full blown regulator black with liquid filled gauge -10 and -6 return
Full blown fuel rail purple -10 each side
2 walboro 450 fuel pumps - both sold
^Message me for what you want ^ n I'll give prices
-Parachute
Only the Chute and the mounting bracket. The bracket mounts to the license plate area where tag is . Can include cable that runs to lever as well -Sold
-Skunk 2 pro series front camber kit 120$ (needs 1 ball joint )
-Aero catch hood hatches with locks 60$
-99-00 front brake assembly hubs calipers rotors etc. could use bottomn ball joints. Has new wheel bearings I just did recently . Aftermarket pads and rotors. Good Working shape - 150$
Some more I'm forgetting but I'll remember
-Dumptubes -SOLD
-650$.
-Parachute
All messages returned
S300 is sold
Intercooler. Piping and bov - sold
Chute sold
Manifold gates and dumps sold
Traction bar pending sale
Pumps and hanger pending sale
Up pipe pending sale
Clutch pending sale
S300 is sold
Chute sold
Clutch pending sale
94eg5squadMD
May 25, 2016 06:14 PM
94eg5squadMD
May 24, 2016 08:03 PM
