Stock 89 civic wagovan no crank
Old May 15, 2016 | 10:30 AM
PRBendz's Avatar
Default Stock 89 civic wagovan no crank
My manual 89 civic Wagovan has no signal to the s terminal on the starter. It cranked fine twice this morning then the 3rd time, less than 5 minutes later, nothing. Remote starter switch fires it right up. I jumped the neutral control switch and rechecked it. The s wire is getting juice at the ignition. Any ideas for next step?
Old May 15, 2016 | 10:41 AM
jlicrx's Avatar
Default Re: Stock 89 civic wagovan no crank
could be a bad starter relay
Old May 15, 2016 | 10:53 AM
PRBendz's Avatar
Is that integral to or seperate of the main relay? I replaced the main with a pulled one a year ago for classic fuel pump prob. I found it, nevermind and thank you!
Old May 15, 2016 | 11:07 AM
fcm's Avatar
fcm
Old Fart
If it is an automatic I am pretty sure there is no starter relay, the Automatic Gear Position Switch is most likely your problem, the starter signal from the ign. switch goes through the AGPS, adjust the switch if out of adjustment, clean the switch if dirty, replace the switch if defective, or you can jump it temporarily, [don't forget if you jump it you do not have neutral safety, engine can be started in gear.
First try starting the engine while moving the shifter from park to neutral, or just off park or neutral, if that works adjust AGPS.
If it is a standard, check Clutch Interlock Switch and/or starter relay. 94
Old May 15, 2016 | 11:18 AM
PRBendz's Avatar
Its a manual, thanks though, good stuff to know. Pretty sure its the relay. Have power to when starting but nothing after.
Old May 15, 2016 | 01:57 PM
PRBendz's Avatar
I was crusing other resources and someone suggested putting a main relay in the freezer... I was skeptical but my starter relay was't working. It worked, car started right up! Not a permanant fix, I ordered another but handy diagnosis trick.
Old May 15, 2016 | 02:48 PM
fcm's Avatar
fcm
Old Fart
The PGM-FI Main Relay has nothing to do with cranking the engine.
The Starter relay will be a 4 pin relay, 30 from ign. switch, 85 will be a jumper from 30 or also from the ign. switch 87 goes to starter, 86 is from the CIS, the switch supplies a ground when you step on the clutch, to test, supply a ground directly from chassis to 86, if engine cranks check/replace the CIS, if still no crank, replace starter relay. 94
slq576
Nov 19, 2013 07:50 PM
Mavrick
Jan 3, 2006 10:13 AM
88 rex
Audio / Security / Video
Oct 22, 2005 10:55 AM
steve_s
12
Oct 9, 2003 02:27 PM
