Bad oil leak after ls vtec assembly
Old May 15, 2016 | 05:41 AM
eksleeper97's Avatar
Default Bad oil leak after ls vtec assembly
Upon start up the coolant over flow jug filled with oil after 15 seconds of running. I have a b18a block with a cylinder support system. Gsr head. Sent the head to the machine shop and they said it had no leaks and was straight. Can't find any major cracks in the block that would cause such a massive leak. Any ideas as to what the heck happened?? Everything was new in this engine build
Old May 15, 2016 | 11:09 AM
civic-steve-94's Avatar
Default Re: Bad oil leak after ls vtec assembly
What head gasket did you use? You did put the plug in the head right?
Old May 15, 2016 | 11:10 AM
The plug is in the head and we used a vtec head gasket. It's 81.5 mm bore
Old May 15, 2016 | 01:48 PM
Do you have a oil cooler?
stadanko
Jul 21, 2009 04:08 PM
94_4door
May 12, 2009 06:38 AM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
null.
Jan 29, 2005 12:02 AM
CRXGSR
Mar 11, 2003 09:28 PM
