Loking for someone to do a headgasket on a f22b1
Old May 14, 2016 | 11:21 PM
Albertochvr's Avatar
Default Loking for someone to do a headgasket on a f22b1
Hi everyone just as I wrote I need someone to do a head gasket on my car I just bought for 500 with 185,000.I know the job is easy and anyone with the ability to change a bicycle tire can do it.The problem is I have 3 bulging discs and I can't be doing heavy lifting.Iam located in the city of Anaheim in Orange County.Iam currently on workers comp so the stealership is out of the question.Any idea or help would be appreciated.
Old May 15, 2016 | 03:29 AM
oldschoolmaster's Avatar
Default Re: Loking for someone to do a headgasket on a f22b1
It's not as easy as a tire
It's about 12 hours in labor
A average price is 600 to 1400
Old May 15, 2016 | 10:40 AM
MAD_MIKE's Avatar
MM Gruppe B
If the head gasket blew from overheating, then the head will need to be machines/rebuilt or replaced. A new gasket will just fail if the head is warped.
Old May 15, 2016 | 01:17 PM
I know I rebuilt a ego 22r by my self turned it into carb setup and stuffed into a 88 Toyota pickup people told me it was hard.Others told me when I bought a 98 Hyundai sonata and had the idea of putting a 4g63 motor into it was going to be to much work and I still did at the age of 19.Iam working on a 96 blazer and Iam going take out the 4l60e and Iam going to put a 4l80e and use it as a tow car for my projects.My other project is a 98 Tacoma with a 2rz that is going to end up as a double duty desert runner.Set your mind on something and see it to the end the rewards are their at the end it's going to be worth it.
Old May 15, 2016 | 01:42 PM
How often do the block warp.
Old May 15, 2016 | 01:51 PM
Or if someone has the ability to swap an engine out and is looking for a vtech f22b1 but doesn't have the money to buy one I'll gladly give them my motor that can be rebuilt I have some one that can rebuild the head for 250 ready to install.
Old May 16, 2016 | 12:06 PM
Dude just realize no mechanic is going to touch this job heads can be warped and also the aluminum block
just sale car and wash your hands unless you got 1500 to drop off in it
Old May 18, 2016 | 10:37 AM
I know what you mean Iam buying a jam f22b and the trans 700 the pair 400 to install.
Old May 18, 2016 | 10:56 AM
angrysmileyface's Avatar
Just because you buy the JDM motor does not mean its had its maintance done. Its still another 2 or 3 hundred just to get the consumable parts taken care of.
Old May 18, 2016 | 11:05 AM
I know Iam putting a timing belt and water pump gates brand.Is there anything recommendations on does two that is not oem
lilshady6796
Feb 3, 2009 07:59 PM
dropped like its hott
Sep 15, 2007 01:11 PM
john457
Jun 5, 2007 05:25 PM
Crackerballer
Dec 29, 2003 04:58 PM
