1998 Honda Civic driver side power window
Old May 14, 2016 | 06:44 PM
98ike01's Avatar
Default 1998 Honda Civic driver side power window
I have a 98 Civic that has power windows and when you roll it up, the back of the window pulls off the guide but the front of the window is still in its track. Does anybody know how you can fix this? I have put new regulators and motors in so that is not the problem.
Old May 14, 2016 | 07:59 PM
r_Senik's Avatar
Default Re: 1998 Honda Civic driver side power window
the rubber weather strip is probably the problem. i had the same issue with my 00 si, and my cousin have it with his ex also.
Old May 14, 2016 | 08:13 PM
Former User's Avatar
Coupe or sedan?
Can you convince us that the installation was done correctly?
Did you align the glass as detailed in the service manual?
Did you lube the rubber side channels with silicone grease? Is the rubber strip or metal side channels damaged?
Old May 15, 2016 | 03:41 AM
98ike01's Avatar
Thank you guys for the replies. The rubber gasket is probably the problem cause it has a few creases in the wrong spots
headrec*
24
Apr 18, 2015 12:08 PM
XanderusMaximus
14
Mar 20, 2010 11:53 PM
fongyz22
Honda Civic (2001 - 2005)
Oct 31, 2007 12:54 PM
lactrain
Mar 31, 2006 09:33 AM
jimmywu
Sep 11, 2004 12:03 PM
