The dowels
Idk how many dowels there should be in the head or block. Today I plan to put my head back on the block. I noticed yesterday there are no dowels in the head. On a spare head I have there are two on the exhaust side. I currently only have one dowel on the block that I plan to install it on. On the exhaust side. Should I go hunting for these things and install them before I install the head? D15
https://honda-tech.com/honda-crx-ef-...sting-3086803/
Should be four dowels. Take a picture of the block and post it up.
Car information
For all technical questions, the following information MUST be included in the first post: vehicle (year, make, model) and engine (if not stock, year, make, model, OBD type). Other pertinent information includes check engine light (CEL) codes as well as engine modifications, such as a turbo kit tuned at 18 psi or a specific throttle body, large injectors, big cams, etc. This information is absolutely essential because, in many instances, members wishing to help in a thread waste their time by posting detailed replies, only to find out the next day that the topic starter left out CRITICAL information. Please respect members wishing to help by taking the time to list or mention crucial information about your car.
no matter what car or engine it is you can actually look at the block and head and determine where the dowels go and how many you need. The head/block are cut to fit the dowels. You can also consult your service manual.
SOHC D-series have (2) dowels on the exhaust side, one near each end - sounds like you have enough to do the job - just pull them out of the head/block and put them in
Reaccion
20
Dec 16, 2010 07:38 PM
