1999 accord 2.3 vtec stutters @ 4,000rpm
Old May 14, 2016 | 10:24 AM
amaidendevil's Avatar
Default 1999 accord 2.3 vtec stutters @ 4,000rpm
My 1999 accord has 2.3vtec I hit @ 4,000 rpm stutters and jerks code p1259 I took VTEC off motor cleaned it and replaces oil pressure switch re installed VTEC turned off code everything fine for a couple hours then code comes back on and @ 4,000 rpm stutters but as soon as I cut off car and recrank it light stays on but car doesn't stutter @4,000 rpmwill run fine for a while but then randomly will stutter @ 4,000rpm. Imcthinking bad VTEC any help is appreciated. Thanks
Old May 16, 2016 | 03:13 AM
user456101's Avatar
Default Re: 1999 accord 2.3 vtec stutters @ 4,000rpm
Check the engine oil level and condition. The engine oil can cause the VTEC to malfunction since it lubricates the VTEC system. Try changing the oil and filter and use a really good oil like Castrol, Mobile 1 or Pennzoil. Also make sure your coolant is at the proper level as well. The coolant goes through the VTEC as well. If you replaced/cleaned the VTEC then you lost some coolant and the coolant could be low. The stuttering could also be caused by the distributor. This generation Accord has a common problem of having oil leak into the distributor. A new distributor can be bought from a place like 1aauto.com for $115 (I got one and it is working just fine).
Old May 16, 2016 | 09:35 AM
Thanks when I cleaned VTEC I topped off all fluids oil and coolant. Turned codes off drove car and around 2 hrs later code p1259 came back and stuttered @ 4,000 rpm but to me the weird thing is cut off car and re crank you can go without stutter @ 4,000 then randomly comes back. Just some open thinking is the VTEC selonoid is just randomly opening and is starting to go out. But I appreciate any thoughts and suggestion I'm willing to try within reason thanks
Old May 16, 2016 | 10:56 AM
user456101's Avatar
I think I found in another post that the VTEC is connected to the speed sensor. If the speed sensor is off or not working right, it won't let the VTEC come on. That would keep it from going above 4000 rpms. I am not an expert but try doing a search on this forum for "VTEC" and/or "won't go above xxxx rpms" and you may see where there are some additional details on this or other ideas. Good luck.
Old May 16, 2016 | 01:24 PM
holmesnmanny's Avatar
check if you have any dents in the oil pan
Dlauth
Oct 23, 2018 10:09 AM
LONO100
Feb 21, 2012 02:04 PM
LONO100
Feb 6, 2012 10:22 PM
99jdm_itr
Nov 1, 2009 12:01 PM
DC2point0
Aug 30, 2003 07:39 AM
