Honda Accord Cl1 Euro R - Master window switch not controlling passenger windows
Old May 13, 2016 | 02:37 PM
H.N.F's Avatar
Default Honda Accord Cl1 Euro R - Master window switch not controlling passenger windows
Hey.
Just after some help with my 2001 Honda Accord Euro R Cl1.
The master window switch on the drivers door fails to work for the passenger side windows, it only controls the drivers side.
However, passenger windows still work at their individual switch located on each door, just not from the master switch.
Any ideas?
Checked fuses, tried jumping the master switch and it kept blowing the passenger window fuse.
My central locking isn't working either, might be linked?
Thanks!
Old May 16, 2016 | 03:35 PM
H.N.F's Avatar
Default Re: Honda Accord Cl1 Euro R - Master window switch not controlling passenger windows
bump help please..
Old May 16, 2016 | 03:49 PM
My 93 accord's Avatar
Have you removed the switch from the door and took the switch apart and clean the terminals individually on easch switch of master door switch I had the same problem and that's what worked
Old May 18, 2016 | 05:42 AM
user456101's Avatar
I had all 4 of mine go bad on a 2000 4-cyl, 4-door SE. You can get replacements on-line at places like 1aauto.com I easily replaced the ones on the back doors and that can save you some money. The front passenger side was too much for me and I ended up having a local shop finish the work for me. I didn't do the one on my drivers door. If it was me I would check to see if it is the switch in the driver's door handle first by swapping it with one I got from a junkyard cheap (and which usually comes with a short warranty so you can return it if you find you don't need it after all). You can practice replacing the switches on a junkyard car as well if you don't want to dive in. There are YouTube videos from places like 1aauto on how to replace all these things.
Old May 18, 2016 | 07:42 AM
holmesnmanny's Avatar
It's common for the master switch itself to go bad after x amount of miles.
EndlEEsss
Feb 23, 2023 03:46 AM
Plinko
Honda Civic (2001 - 2005)
Aug 9, 2014 07:52 AM
hondagal2004
Nov 27, 2013 07:55 PM
ridenslide65
Sep 28, 2008 07:29 PM
