97 Civic HX - Engine Swap
Old May 12, 2016 | 04:03 PM
96eksinglecam's Avatar
Default 97 Civic HX - Engine Swap
I have a 97hx with a d16vtec and it's on its last leg.
I can't find a motor for the money I'm trying to spend.
I did find a d15 VTEC so my question is can I swap the d16v for the d15v without allot of modification?
Cuz if I am going to have to do allot of modification I think I'll just save and get a bigger motor so it is worth the time money and aggravation
so any suggestions
Old May 12, 2016 | 11:43 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 97 Civic HX - Engine Swap
google is your friend. mama bird is sleepy.
Old May 14, 2016 | 01:38 PM
conor97hx's Avatar
I would save up personally and get a d16.
Old May 14, 2016 | 01:52 PM
Former User's Avatar
Do you have the stock D16Y5? If you can't find the direct replacement, were you considering this:
https://en.wikipedia.org/wiki/Honda_D_engine#D15B
Old May 16, 2016 | 07:10 PM
chrysler kid's Avatar
Rebuild the y5.
There is no modification required to swap in another d series, it is all wiring. Would you rather have the car down for a month for a good rebuild and everything work, or spend a weekend swapping the motor and having to drive a car that is an electrical mess and doesn't run right
Hint - don't cut corners. Find another good d16y5.
Old May 18, 2016 | 09:09 AM
jim chuck's Avatar
Yes, you can swap them. What leads you to believe that the 16 is on its last leg?
Feb 18, 2013 08:59 AM
tamadrummer1120
May 9, 2012 06:01 PM
JesusGLS
May 11, 2006 10:39 AM
