91 civic si - b16 to a6 swap keeps dumping fuel
Old May 12, 2016 | 12:51 PM
_EF9's Avatar
Default 91 civic si - b16 to a6 swap keeps dumping fuel
I'm swapping my b16 out of my life 91 civic si back to the a6 and I'm pretty much compete done. While going under to put my shift linkage on, I keep seeing drips under my intake. Touched it and it was fuel. Got out under the car and my fuel rail was getting flooded. I removed my ecu, disconnect battery, main relay and harness to my fuel tank. It's still dumping fuel out. Need help ASAP!
Old May 12, 2016 | 12:55 PM
_EF9's Avatar
Default re: 91 civic si - b16 to a6 swap keeps dumping fuel
Gasoline is coming out every damn line. Fuel filter line, it's coming nonstop. Line to my fuel regulator is coming nonstop. I'm running out of containers! Garage is covered in fumes. I have fans blowing the fumes back out. Anyone?!
Old May 12, 2016 | 01:18 PM
.Manny.'s Avatar
Touching My Member
1. disconnect battery
2. fix leaks
Old May 12, 2016 | 02:37 PM
_EF9's Avatar
2. fix leaks
That's what I thought but it wasn't. I disconnected everything that had to do with my fuel. I found out I had my stupid canister line that plugs into the firewall, i had a cap over it. I guess air wasn't circulation for the fuel to flow? Not sure but it's fine now. After almost 2 gallons came out.
Gremlin_rex
Apr 20, 2012 08:44 AM
93FastLs
Jun 19, 2005 08:19 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
LBR92DA-T
Oct 24, 2003 07:48 PM
ejprimo
Aug 24, 2002 02:31 PM
