Crx lights
Old May 7, 2016 | 05:45 PM
civiccrxdx's Avatar
Default Crx lights
So I have this problem that every time that I put a fuse in for my tail lights it just pops the fuse idk what's wrong it just started doing it
Old May 7, 2016 | 06:26 PM
v4lu3s's Avatar
RTFM
Default Re: Crx lights
You have a short somewhere. I would unplug each tail light bulb then try a fuse. If it doesn't pop then plug one light in at time too isolate where the short is.
Old May 9, 2016 | 03:33 PM
fcm's Avatar
fcm
Old Fart
Do you have an aftermarket stereo in the dash?
If so, pull it and check the wiring, make sure the cars illumination lead is not shorting out, not used on most aftermarket head units. 94
Old May 9, 2016 | 04:26 PM
Triller831's Avatar
If it is not an aftermarket stereo and the short is not in a bulb socket, do a visual inspection of the wire. All the way back the harness, since anywhere it was crimped, cut, or rubbed could be the short.
If a visual doesn't save you, only god or short finder will.
bitozi
Audio / Security / Video
Jan 15, 2009 02:04 AM
91civicsikid
Oct 28, 2008 02:23 AM
tdizz07
Sep 20, 2007 07:45 PM
slow91crxdx
May 6, 2007 08:55 AM
hondaheadache
Aug 5, 2006 07:57 PM
