Weird wiper issue in 2000 SI
Old May 6, 2016 | 07:10 PM
FeRReTTi's Avatar
Default Weird wiper issue in 2000 SI
Ok, so there's 3 wiper settings. Intermittent, constant, and fast, right?
I noticed only the constant and fast setting work, and intermittent didn't. So I messed around with different combinations and noticed that the intermittent setting only works when I have the headlight switch turned to either have the parking lights on or the headlights on, but doesn't work with the headlight switch off. Is this the way it's supposed to be? Or was the wiring messed with at some point?
Old May 6, 2016 | 09:11 PM
Former User's Avatar
Default Re: Weird wiper issue in 2000 SI
Do these input tests with and without the parking lights on.
Old May 8, 2016 | 03:11 AM
FeRReTTi's Avatar
Fuse 26 definitely isn't blown. I doubt its a faulty wiper switch since the switch operates the other settings correctly and the motor should be fine since all the speeds work
TanaVP
Lighting
Sep 2, 2014 03:46 AM
Maine323
Oct 18, 2013 12:34 AM
gotablk95gsr
Jan 10, 2009 09:14 PM
Ham'ed Hatch
Audio / Security / Video
Jan 7, 2003 11:14 PM
ImprtTuner88
Nov 19, 2002 04:09 AM
