Too much bearing clearance??
Old May 3, 2016 | 01:13 PM
SDvTecKing's Avatar
Default Too much bearing clearance??
So I'm in the middle of building a b20 block and after measuring both my main bore and crank shaft. I'm left with .004 bearing clearance.
Have in mind that the crank is standard spec but the main bore was bored out which is probably why my clearance is out of (spec .002).
Would I be ok running .004 with ACL bearings???
Please help thanks
Old May 3, 2016 | 05:20 PM
Pro-SeriesFab's Avatar
Default Re: Too much bearing clearance??
.004 overall right? (.002" per side)
That's a ton of clearance either way. What are you measuring with?
I don't even run that much clearance in a blown alcohol engine with straight 50wt oil
Old May 4, 2016 | 02:51 PM
flesh199's Avatar
Yeah its too much 0.004.
You mics everyting 3 times to be sure of the actual i.d of the main journal?
Old May 4, 2016 | 05:21 PM
SDvTecKing's Avatar
Yes I'm measuring with an Outside Micrometer and telescopic gauge.
I will update you guys if i figure it out thanks for the replies
dallasyoung
Nov 2, 2011 04:53 PM
ej93
13
Nov 1, 2010 02:41 PM
ziggy3784
Apr 30, 2009 07:48 AM
xxmastermindxx
May 6, 2007 09:17 AM
HybridBert
22
May 11, 2004 03:27 PM
