91 Civic EF wiper linkage bushing
Old May 1, 2016 | 04:20 PM
Yuta's Avatar
Default 91 Civic EF wiper linkage bushing
Hi
My wiper decided to quit. The motor is running but the linkage is totally off the ball. The bushing is gone. I looked up on youtube, it seems like people swap out the entire mechanism. Is it possible you put new bushings on the bar? Any instructions? I can't go without wiper...
Old May 1, 2016 | 06:32 PM
Cementups's Avatar
Default Re: 91 Civic EF wiper linkage bushing
You can't buy JUST the bushing. You have to buy the whole linkage. And don't buy old ones, just pony up the money for brand new ones. If you buy old ones they will bust out too. They are still available at the dealer. I just bought one last year.
Old May 4, 2016 | 08:06 PM
91DxRob's Avatar
^--What he said...
I've been there with my 91 before... Uh.. check the wiper transmissions (the posts wiper arms connect to) as well... I just replaced the linkage originally.. and a few months later the transmissions went out... >.> two very expensive trips to the mechanic...
Old May 13, 2016 | 05:22 AM
Yuta's Avatar
I found this wiper linkage assortment kit in autozone. Will it work?
Old May 13, 2016 | 07:04 AM
existanzcivicb20's Avatar
Yes and also there is a cheaper assortment that I bought available at Autozone, Orileys, or Advanced Auto Parts for $4.99
It calls out for Ford, Chevy, Chrysler, Nissan but I made it work for my CRX all I had to do is make the hole in the linkage a tiny bit bigger and it fit right in. Took me about 5 min todo.
Old May 13, 2016 | 10:35 AM
smilindave's Avatar
Never tried those, just ponied up at the stealership. All was good, lubed the gearbox and just like magic I had wipers again.
Regards
Dave
Old May 14, 2016 | 01:21 PM
Yuta's Avatar
Looks like brand new ones are like twice expansive compare to newer models... It's quite a investment...
Old May 15, 2016 | 07:05 AM
Yuta's Avatar
Hi, how did you put the bushing on the linkage? Just snap on?
Old May 15, 2016 | 05:27 PM
acmoc's Avatar
LOL No, vice, larger socket, wd40 drop them in boiling water to soften fisrt.
Need to trim the insert side a bit too to get it started
Old May 16, 2016 | 04:18 AM
I took a drill and made the hole in the linkage a tiny bit bigger and the snapped right in. But I would also dip them in the hot water like acmoc said Im sure it would help.
efugate91ef
Transmission & Drivetrain
May 10, 2017 01:36 PM
historic4thewin
Jun 6, 2013 12:02 PM
ChristopherJaso
Jun 9, 2012 04:56 PM
hammergunner
Feb 26, 2009 02:12 PM
