Car starts runs then dies
Old May 1, 2016 | 05:58 AM
stevlover's Avatar
Default Car starts runs then dies
I have searched and searched and have yet to find an answer to my problem . I have a 2003 honda civic SI EP3, I recently swapped out my high mileage engine (K20A3) and replaced it with a JDM K20A. I used the original K20A3 harness and swapped over all sensors everything plugged in nicely, I had the PNF ecu KPRO'D V4. here is the issue Im having as soon as I start the car it runs for approximatelt 3-4 seconds and then just abruptly die. it will start up everytime but does the same thing everytime. I checked fuel pressure, spark plugs and ground, I checked and double checked all sensors and connections . I checked for power at the fuel pump and injectors and coils , I removed the he engine and checked the timing, I tried many different basemaps and result still the same. It has been over six months of searching the forums and still no positive results at this point Im willing to try almost anything I really need someone who has had this problem and or knows how to fix this problem to chime in
Any help would be greatly appreciated
Old May 1, 2016 | 02:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: Car starts runs then dies
What is missing when engine stalls?
Do you lose power to the injectors?
Do you lose injector pulse from ECU?
Does fuel pressure drop?
Do you lose spark?
Check for power to the fuel pump when engine stalls. 94
Old May 2, 2016 | 12:59 PM
stevlover's Avatar
I do not lose fuel pressure
and all other signals just abruptly stop
Old May 4, 2016 | 06:11 AM
fcm's Avatar
fcm
Old Fart
Signals??? 94
Old May 4, 2016 | 04:19 PM
stevlover's Avatar
what exactly do you mean by "94"
stumpedtech
Aug 10, 2012 03:56 PM
JsSIR
Apr 28, 2009 05:25 AM
JorgeYaHeard
Jul 25, 2007 08:35 AM
89bluehatch
Feb 11, 2007 08:16 AM
