SRP 149202 10.3:1 CR for turbo application
I got a hell of a deal on some brand new SRP 149202 Pistons and JE rings. 125 for everything brand new in the box never used. I am building a turbo set up and will be using e85. I was curious if I would be ok using these pistons for my set up. They said they are for nitrous applications.
Yeah they'll work well for you. I'd say .0035 piston to wall the srp doesn't expand as much due to the higher silicon content in the material so tighter piston to wall is acceptable and will keep the engine quieter on cold starts and reduced skirt wear. I loved my srp's when my car was daily just wish they weren't low compression. The 10.3:1 will make your engine much happier and have pep out of boost. Good luck on the build and enjoy
flatblackracing
Jul 22, 2006 08:10 AM
FragSyndrome
Jul 25, 2003 02:41 AM
