93 Civic/D15B VTEC-E JDM swap - CEL code 14 or 24?
I recently got a another civic
93 Honda Civic Hatchback
It has a JDM D15B in it, thing is, the check engine light is on.
So I watched a video on YouTube on how to read the codes seeing that it's Obd1. Pretty easy. The thing is I can't really tell if it's code 14 or 24 ?
Paper work on the motor states it is a JDM 1.5L D15B SOHC VTEC-E
Another thing is, I went to Advance Auto to try and get new spark plugs and wires and they can't seem to tell me the correct ones I need because my hatch is a DX model but has a different motor in it that what's shows in there system for my year make and model. When I go to AdvanceAuto website, and select my car, the last option shows D15B7. Do they use the same spark plugs as the JDM??
re: 93 Civic/D15B VTEC-E JDM swap - CEL code 14 or 24?
I honestly don't know what are installed right now. I just got the car last week. I'm doing a tune up tomorrow hopefully. I guess I could take one out and see if I can any markings on them.
Originally Posted by tony_2018
What ecu? and on the cam sprocket cover there should be some labelling that identifies what spark plugs to use.
I'm guessing that's the white cover on the right side of the motor? If so. I don't see any labeling. Looks like they've been peeled off.
This motor was pulled out of another vehicle and put in my hatch.
On the valve cover, someone wrote in a marker the words "z-1 model" but on the block it says D15B
I know I did a cross-reference for my 3 stage vtec d15b's timing belt and it matched the VX.
So I'm guessing everytime I need a part, just use my reference as 93 Honda Civic VX?
Because I'm about to go to Walmart and get oil & a filter, and making I'll use the VX option to chose my filter.
