94 DelSol D16Z6 Plug Fouling
Old Apr 24, 2016 | 06:26 PM
wraprail's Avatar
Default 94 DelSol D16Z6 Plug Fouling
D16Z6 shows 200,000+ on the odo, to my knowledge the motor is stock but has been apart at some point in its life (has ARP head studs)
Came with no history
Couple months ago started running like had a mis-fire pulled the plugs and number 4 was fouled. Not sure if is oil or fuel
Ran compression then and was good. 180psi on all.
Swapped the plugs around and ran better. Was drive able but getting worse.
Month ago I adjusted the valves, new platinum plugs, Plug wires are a year old and look fine. Replaced fuel filter
Soon after check engine light comes on. Still running but like crap.
CEL code 9. Great I thought. Finally an answer! Cylinder sensor!
Replaced distributer with brand new from Napa (expensive) and ran the valves again, expecting an improvement. Nope.
Then this last week another cel, code 1. Oxygen Sensor. This must be it!
I reset computer and drive just to verify 3 times code 1.
Then I get a code 43.
So i'm confident is a bad oxygen sensor. Today $50 for a Bosch, install it and runs worse than ever.
Just checked compression again, 180psi on all four
Here are the plugs tonight. The black plug is #4. Picture is upside down
I really could use your guys help. Could it be valve seals?
Old Apr 24, 2016 | 06:56 PM
mk378's Avatar
Default Re: 94 DelSol D16Z6 Plug Fouling
Swap the fuel injector for that cylinder with one of the others. See if the fouling moves to the new cylinder-- that would mean the injector is bad.
Old Apr 24, 2016 | 07:47 PM
wraprail's Avatar
I'm gona try this right now...
Old Apr 25, 2016 | 01:31 PM
White_EG1's Avatar
Use denso for the 02 sensor.
Old Apr 25, 2016 | 01:39 PM
Former User's Avatar
Your pic link is broken.
Old Apr 25, 2016 | 01:49 PM
DumpdEJ6's Avatar
I like the tuna here
Or NTK, both are good.
Old Apr 27, 2016 | 08:16 PM
wraprail's Avatar
Well I swapped the injectors around and so far car is running great. The tips were pretty dirty so I cleaned them up with some carb cleaner. See how it is in a week or so.
Thanks for the help.........
Old Apr 27, 2016 | 08:17 PM
wraprail's Avatar
Fixed. (i hope)
projsectEF
May 22, 2007 03:23 PM
That Sob
Sep 2, 2005 09:19 AM
ibanender
Jun 29, 2005 05:36 PM
RyanEJ8
Jan 20, 2004 05:02 AM
1hotintegra
Jun 11, 2003 02:07 PM
