skunk2 intake manifold?
Old Nov 7, 2002 | 09:04 AM
marques4130's Avatar
Default skunk2 intake manifold?
has anybody put a skunk2 intake manifold on a b16A, if you have how good did it work and was it worth it?
Old Nov 7, 2002 | 10:15 AM
Kool305's Avatar
Default Re: skunk2 intake manifold? (marques4130)
Yeah i've heard it does make a difference and gets the job done...isnt that what you want??? GO FOR IT...I would get ITR manifold *SOME PEOPLE SAY ITS THE SAME ***** but thats just me...GOOD LUCK!!
Old Nov 7, 2002 | 11:32 AM
krazn's Avatar
Default Re: skunk2 intake manifold? (DOHC_VTEC)
it is not worth it on a b16. skunk 2 manifolds give u high end hp which u already have. it will not give u much torque. its a good mod for LS engines where they lack high end hp. but u already have that. u needs torque yos.
Old Nov 7, 2002 | 12:49 PM
RosebloodSol's Avatar
I have it installed on my B16, and have documented proof of increased HP of 3-5 on the low end and 7-8 up high.
I would recommend getting this item if you want the increased air volume on the intake. However, keep in mind that the opening is larger than the B16 throttole body so you will have to bore it out or get the ITR throttle body to compensate.
Old Nov 7, 2002 | 12:51 PM
1strdtko's Avatar
Default Re: skunk2 intake manifold? (RosebloodSol)
How does the JG Victor X rate against the Skunk?
Old Nov 7, 2002 | 03:34 PM
OEMJDM's Avatar
Default Re: skunk2 intake manifold? (1strdtko)
It depends. the JG would be better than the skunk if ur going F/I but if ur going all motor it would be the other way around.
Old Nov 8, 2002 | 02:29 AM
D16Z6racing's Avatar
Default Re: skunk2 intake manifold? (C5_ALLMOTOR)
All the Skunk inatke manifold is, is the Integra Type R manifold that's been ported out.
Old Nov 8, 2002 | 04:37 AM
h82lose2vw's's Avatar
Default Re: skunk2 intake manifold? (buster13)
i think u should sell yours and buy a type r because the only difference between them is that at the factory they port and polish the si and make it a type r ...this is cheaper and will be just as good and it is amuch easier installation
Old Nov 8, 2002 | 05:58 AM
4g4me's Avatar
Default Re: skunk2 intake manifold? (h82lose2vw's)
Haha......not true the ITR manifold has larger shorter runners, the intake makes less of a turn up,(straighter runners) and the plenum is larger as well. Good try though, the B16(SI) manifold is poo poo, nice try though, read on my friend.
andrewxxcarlson
Nov 24, 2011 08:51 AM
azn99si530
25
Mar 22, 2007 03:18 PM
bfong13
38
Dec 13, 2004 12:52 PM
Hybrid Invasion
44
Oct 2, 2003 08:04 PM
vtec8k
Feb 18, 2002 06:59 AM
