One side of rear toe 1/2 degree out of spec. Will aftermarket toe arm correct that?
Old Apr 22, 2016 | 02:37 PM
scheibler's Avatar
Default One side of rear toe 1/2 degree out. Pic of subframe
Factory essentric bolt is maxed out on my toe arm and it is 1/2 degree out 9f spec...not half degree from zero! So one side is zero, but the other is toed in out of spec eating my tires. Thought I fixed it by replacing the arms and siezed essentric bolts.
Will Megan racing adjustable rear toe control arms bring it back into spec?
Old Apr 22, 2016 | 05:53 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: One side of rear toe 1/2 degree out of spec. Will aftermarket toe arm correct tha
If the arms are new and the adjustment does not work, then check that the subframe has not been bent or shunted to the side.
Old Apr 22, 2016 | 10:20 PM
scheibler's Avatar
Subframe has these two indentions from a jackstand....<br/><br/>That enough damage to cause that? I went ahead and ordered megan racibg adjustable tie arms hoping tgey adjust farther then stock. Really hoping i dont have to replace the cross beam
B_Swapped93
Acura TSX
Jan 7, 2019 05:10 PM
e.p
Sep 13, 2016 10:41 AM
jeddyten
10
Mar 11, 2013 05:33 PM
PRoJecTSLeePaLoT
Mar 22, 2007 10:35 AM
mingbling96
May 30, 2006 01:18 PM
