headlight bulb replacement
Old Apr 22, 2016 | 08:09 AM
berra_15's Avatar
Default headlight bulb replacement
hi, i have a 97 honda accord sedan ex, was wondering how I'm supposed to change out the passenger headlight bulb seeing as theres no room to get your hand in there to pull the bulb out. thanks!
Old Apr 22, 2016 | 08:51 AM
coolswimmerjon's Avatar
Default Re: headlight bulb replacement
The coolant reservoir lifts straight up to make more room. If that isn't enough for you the air intake box is only held in by a couple 10mm bolts if I remember correctly.
Old Apr 22, 2016 | 09:55 AM
berra_15's Avatar
ok thannks! do i need to disconnect anything so no fluids come out or am i fine to pop it straight out ?
Old Apr 22, 2016 | 11:48 AM
just remove the cap and the entire reservoir can slide right out, no other connections.
Old Apr 22, 2016 | 11:50 AM
berra_15's Avatar
awesome thanks!
06civicoolie
Honda Civic (2006 - 2015)
Sep 28, 2007 08:45 PM
sdsviet
Aug 15, 2004 01:54 PM
beantowncoupe
Apr 24, 2003 11:50 AM
aaronic
Sep 19, 2002 09:32 PM
Akshay
May 8, 2002 11:22 AM
