Transmission & Drivetrain Gearboxes, Differentials, Clutches
What is this plug on the front of 1996 Automatic Integra b18b Transmission
Old Apr 22, 2016 | 07:28 AM
andrew714's Avatar
Default What is this plug on the front of 1996 Automatic Integra b18b Transmission
Hello, could anyone tell me what this plug is ? The transmission is from a 1996 Integra, b18b, automatic.
Thank you
Old Apr 23, 2016 | 04:36 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: What is this plug on the front of 1996 Automatic Integra b18b Transmission
Is that for the lower pair of shift solenoids? If it is the plug should be attached to the black stand on the cooler line, that is between the vent(rubber cap) and upper pair of shift solenoids.
Old Apr 24, 2016 | 01:50 PM
andrew714's Avatar
thank you. i'm trying trying to do an automatic b series swap into my eg. I have to manually wire the external TCU from the integra seperately - into the following: main shaft speed sensor, counter shaft sensor, and the lower shift solenoids.
Wish me luck
yerpJDM
Aug 14, 2010 05:51 PM
m00nr0ck Si
May 12, 2007 05:35 AM
akteamster
Oct 21, 2006 11:05 AM
b16clutch
Dec 15, 2005 10:24 AM
KeithsDAteg
Jan 24, 2004 05:24 PM
