sway bar options for my 97 four door
Old Apr 21, 2016 | 12:55 AM
shmooly's Avatar
Default sway bar options for my 97 four door
how's it going guys?
I'm looking to put a sway bar on the rear of my 97 four door. what are my options?
I've heard the gsr sway bar will bolt right up.. true? I have blox rear lower control arms.
how about a bigger one for the front? what brand? I'd like the thickest one that's reasonable.
links/any info / pictures you've got would be dope. let me know, thanks.
_isiah
Old Apr 21, 2016 | 05:41 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: sway bar options for my 97 four door
_isiah
Google. The link is Google
Here's a freebie; https://www.google.com/search?site=&....3.UrdTWclBdbU
eH.
Old Apr 23, 2016 | 03:48 PM
DVDr's Avatar
Ill post my setup.
running rear ITR sway bar ( 22mm I believe ) , with 99-00 SI links and oem control arms. and ASR rear brace.
Works fantastic . ( dont have super stiff springs, so makes a nice difference, im sure if I were to run a much stiffer spring it would be different)
Also running a 24mm OEM acura 1.6 EL ( from canada ) front sway bar. Similar to CTR end links.
GSR will also work , as long as you use the SI 99-00 rear end links ) . the GSR not being super thick shouldnt rip off the mounting points, but if the car has seen salt, I would get a rear brace.
92DAIntegraXSI
Jul 10, 2007 04:06 AM
andyvaj
Mar 18, 2005 09:51 PM
jtl
Apr 1, 2004 04:24 PM
Jt240
Oct 7, 2002 11:28 PM
