AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Devils Own Kit
Old Apr 20, 2016 | 06:33 PM
ESP.net's Avatar
Default AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Devils Own Kit
Hello guys, I am in need of some wiring help. P28 s300v2 ecu EBC PWM
I have devils own injection kit with progressive controller...
I have 6 wires left to be firgured out. I am trying to wire in the AEM water/fail safe. In the pictures it is first last 2. The First 3 are for the devils own kit.
I need help on what the following wires will be hooked up to. Currently I had an aftermarket transducer to be able to adjust and swap maps and boost level when pressure in line drops. I am doing away with this. I had 2 wires one going to A24 and D4. To trigger maps.
The 6 wires 2 which either go to A24 and D4. Need to know what goes where in order to get this AEM fail safe fired up. Which wires go to the controller and where????
On the AEM failsafe
White?
Brown?
Yellow?
Blue?
Green?
Orange?
Old Apr 20, 2016 | 07:18 PM
ESP.net's Avatar
Default Re: AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Deivils Own Kit
Orange goes to blue wire from controller ?
Yellow ECU Switch Failsafe Use for nitrous map ?
Brown ECU Sensor Ground ?
White ECU (Log the data) PR Pressure Voltage ?
Green Optional Boost-Safe ?
Blue goes to chassis Ground ?
D4 as switched to ground inputs
A24 ECU power ground
Old Apr 21, 2016 | 09:44 AM
ESP.net's Avatar
Help
Old Apr 23, 2016 | 10:48 AM
ESP.net's Avatar
Default Re: AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Devils Own Kit
up
Old May 3, 2016 | 06:17 PM
ESP.net's Avatar
Help please
Old May 8, 2016 | 10:55 AM
ESP.net's Avatar
up
Old May 8, 2016 | 12:37 PM
ESP.net's Avatar
If anyone can take the time to figure out the 6 wires. I will Paypal $50. Thanks
Old May 8, 2016 | 04:27 PM
ESP.net's Avatar
How I see there needs to be a relay on either Blue low side or Yellow high side. So you can't use both to sense? And cut boost. If you can better direct me on which wires need to be hooked up.
So far I see it as:
White analog + D4
Brown wire analog - A24
Yellow Hi Side +12v ????? goes where
Blue Low Side - ???? goes where
Green Fluid Leve Sensor - Yellow on Devils on controller
Orange Injection Percentage - Blue on Devils on controller
Old May 8, 2016 | 04:59 PM
ESP.net's Avatar
Scratch the below diagram. A11 WIRE WOULD NOW BE 12V Power wire of the EBC MAC SOL.
Old May 9, 2016 | 10:57 AM
ESP.net's Avatar
This was brought to my attention how the wires should be wired.
No need for relay of any sorts to get once detected too high or low then goes into spring pressure and or secondary map????
Orange on AEM to blue wire on Devils own kit. Logs pump percentage.
Green on AEM to fluid level switch/yellow on devils own. Error if fluid level is low
Bue on AEM to d4. Ground switch for changing map.
Yellow on AEM not connected. No 12v out needed
White/brown connected only if you are logging flow then they would go to an 0-5v input on ECU.
So White and Brown really not needed if I don't care to log? still will work properly when problem arises to high or low on pressure and secondary map still work?
No need for A24 power ecu GROUND to be hooked up? Just one wire D4 for switch of map? Thanks
Old May 9, 2016 | 03:47 PM
ESP.net's Avatar
Talked to AEM this is what they told me:
Orange on AEM to Blue on Devils Own Kit/ Logs pump percentage/ Goes to negative on pump wire
Green on AEM to Yellow on Devils Own Kit Fluid Level Switch
Blue on AEM to D4 Ground Switch for changing map
Yellow on AEM would be GOING TO A24 ECU Power GROUND Blue and Yellow need 2 wires to switch the map. Not just one?
White and Brown connected only if logging flow 0.5v. ECU (Imagine would go to Analog pigtail pins on s300v2)? (If wanted)
Old May 11, 2016 | 11:51 AM
ESP.net's Avatar
As of right now 5/11 it does seem like maybe I will need a relay to do it correctly. Seems I would have one tune already pump gas tune then as long as it is triggered with the relay the other tune will kick in with more timing and added boost. Then if a high or low peak happens with the pump flow it will trigger or de-trigger the relay forcing into pump gas and wastegate spring. arghhh
Instead of using the A11 wire now... which wont work it would be the power side so the other 12v wire on the EBC.
Old May 12, 2016 | 05:52 AM
ESP.net's Avatar
Someone had brought below to my attention. So confused may or may not need relay? Hmmmm
If you are hooking up a relay to trigger your boost control solenoid here is how I would do it. Yellow wire from AEM to pin 85 on relay, pin 86 to ground, pin 87 to boost control solenoid. Other wire from boost control solenoid to pin a11 on ECU. Pin 30 on relay to switched 12v. Set the failsafe up so that the yellow wire is powered when meth is flowing. When meth is not flowing the 12v is deactivated from the boost controller and you have wastegate psi.
edit: I just noticed that hondata has high and low boost control switching available in settings. You wouldn't actually need a relay or the yellow wire connected at all. Just set Hondata high boost to be active with D4 and your all set. You also wouldn't be limited to wastegate with no meth if you choose that way.
Old May 12, 2016 | 06:46 AM
ESP.net's Avatar
so what you saying is like what below was brought to me?? So am still confussed do I hook the Green wire boost safe/aux to D4. Where do the Blue Low Side and Yellow High Side wires need to go?????????
With the AEM failsafe controller I normally tie the green wire from the controller to D4. I enable a generic output and set the input for D4, set the conditions super low so when the controller outputs the failsafe signal it goes into the programmed fuel and ignition 2-d tables. I usually add a ton of fuel and pull a ton of ignition timing. See attached screen shots. On a turbo car using the boost by gear feature I also set the low/high boost switch to D4. I set the “high” boost by gear table to a low target (3% output) so that it kicks the boost down to waste gate level. I use D4 specifically because it will also illuminate the CEL light when the feature is turned on, which gives a visual warning what is going on. Just follow AEM’s instructions for the fail safe controller installation/wiring, but specifically tie the green wire to D4. No relays are needed, its a ground output.
Old May 12, 2016 | 09:36 AM
ESP.net's Avatar
More insight from someone:
The green wire on AEM is an input to the failsafe. It will not output a ground signal to switch maps. The blue wire is your ground output to switch maps. You want the green wire tied to the fluid level so when you fluid level is low the AEM is aware. No relays necessary. In s300 trigger boost and secondary maps off d4. Yellow wire is a switched 12v output which is not needed for your setup.
Old May 12, 2016 | 01:35 PM
ESP.net's Avatar
Side not talked to SpeedFactory said same no relay needed will be tuning it there shortly.
Laojoeturbo
Jan 12, 2010 10:21 PM
[Ennis_D]
Engine Management and Tuning
Jan 7, 2010 11:01 PM
[Ennis_D]
Jan 7, 2010 12:52 PM
