AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Deivils Own Kit
Hello guys, I am in need of some wiring help. P28 s300v2 ecu EBC PWM
I have devils own injection kit with progressive controller...
I have 6 wires left to be firgured out. I am trying to wire in the AEM water/fail safe. In the pictures it is first last 2. The First 3 are for the devils own kit.
I need help on what the following wires will be hooked up to. Currently I had an aftermarket transducer to be able to adjust and swap maps and boost level when pressure in line drops. I am doing away with this. I had 2 wires one going to A24 and D4. To trigger maps.
The 6 wires 2 which either go to A24 and D4. Need to know what goes where in order to get this AEM fail safe fired up. Which wires go to the controller and where????
On the AEM failsafe
White?
Brown?
Yellow?
Blue?
Green?
Orange?
On the AEM failsafe
White?
Brown?
Yellow?
Blue?
Green?
Orange?
Orange goes to blue wire from controller ?
Yellow ECU Switch Failsafe Use for nitrous map ?
Brown ECU Sensor Ground ?
White ECU (Log the data) PR Pressure Voltage ?
Green Optional Boost-Safe ?
Blue goes to chassis Ground ?
D4 as switched to ground inputs
A24 ECU power ground
ESP.net
May 12, 2016 06:01 PM
ESP.net
Engine Management and Tuning
15
May 12, 2016 01:35 PM
Laojoeturbo
Jan 12, 2010 10:21 PM
[Ennis_D]
Jan 7, 2010 11:01 PM
