FS:Turbo part out, Full race, Borg warner, precision, ID2000, Nitro Performance,fuel
Old Apr 20, 2016 | 05:12 AM
heetstroke's Avatar
Default FS:Turbo part out, Full race, Borg warner, precision, ID2000, Nitro Performance,fuel
David heeter
Valdosta, ga 31605
2292512676
Full race t4 twin scroll manifold dual 38mm gates, with 4 inch up pipe and dump tubes. $1050 shipped
Borg warner t4 s400sx 67mm fmw turbo with 1.25 upgraded exhaust housing $1050 shipped
Precision 5431 t3 .60 ar turbo with .63 4 bolt exhaust housing. SOLD
Treadstone 4.5 inch intercooler $300 shipped
K24 Darton Sleeved Block and mint k24 crank, block needs to go to 87.5. SOLD, thanks Tyler
I'd 2000 injectors just came back from fic for cleaning SOLD
Fuel lab 4303 fuel pump with mounting bracket , I made over 800 with e98 at 65% duty cycle with 50lb base fuel pressure, should be able to make 1000hp with this pump abd I'd 2000s. $350 shipped
Nitro performance 5 gallon stock location fuel cell, SOLD
Text for fastest response and more pics 2292512676 All prices are obo. Photos can be found in this album and I can te,t or get more at you request. 2292512676 Civic by David Heeter | Photobucket
Old Apr 20, 2016 | 06:01 AM
heetstroke's Avatar
Default Re: FS:Turbo part out, Full race, Borg warner, precision, ID2000, Nitro Performance,f
Also have the following k series aftermarket gear set. 1-5th with input and main shafts. Completely assembled gear stacks with oem 5th gear. Just install ring gear on you dofferental and drop and shim the shafts in your case
Gear X helical cut 1-2 turbo gears with input shaft (2.31, 1.65 ratios)
Ppg synchro engaged 3-4 turbo gears (1.19, .909 ratios)
Oem 4.3 final drive, main shaft, and 5th gear. Brand new synchrotech carbon lined synchros with hubs and sliders.
(No trans case or diff included)
SOLD, thanks Tyler
Old Apr 21, 2016 | 04:32 PM
heetstroke's Avatar
Trans gears
K24 Sleeved Block and crank sold, Thanks Tyler
Old May 1, 2016 | 04:09 PM
heetstroke's Avatar
Bump Full race manifold needs a new home
Old May 11, 2016 | 04:41 PM
heetstroke's Avatar
Parts need a new home
Old May 16, 2016 | 09:09 AM
heetstroke's Avatar
Price drops
Old May 27, 2016 | 05:12 AM
heetstroke's Avatar
Bump
Old Jun 13, 2016 | 03:34 PM
heetstroke's Avatar
Bump
Mr.Spec
Jul 14, 2014 07:26 AM
K20A2DELSOL
Aug 18, 2010 08:29 PM
blmracing
Nov 6, 2003 06:29 PM
TurboT
Aug 19, 2002 08:23 AM
