p61 rod broke need a replacement
Old Apr 19, 2016 | 10:11 PM
clomonolo's Avatar
Default p61 rod broke need a replacement
Bearing went out and bent my rod then chipped the piston. Can't find p61's anywhere. After searching countless hours I might have to use pr3 rods and possibly pistons. Will it work and what an I losing. Rod length p61 5.209 pr3 is 5.290 how do I make this work or are there other options?
Old Apr 20, 2016 | 01:32 AM
rollinmyda's Avatar
Default Re: p61 rod broke need a replacement
You can use PR3, P30, or P73 pistons and they will bump your compression slightly. A lot of people use those when rebuilding B17s because it makes a bit more power as long as you're tuning for them. You do need to use P61 rods though as they are an oddball length. There's usually some on eBay for sale although I haven't looked lately. Or try G2IC, you'd have better luck there then here.
itslogz
Apr 28, 2016 10:39 AM
CaliforniaDad
Jun 30, 2011 11:44 PM
DarkTeg94
Dec 26, 2005 10:30 PM
NSTY Z33
Aug 20, 2004 10:36 PM
