It flooded and my car was on an incline.
I need help also !!
It flooded and my car was on an incline. The rear end of my car was pretty submerged, while the front end only got water to about a quarter of the front tire. When the water finally began to go away, I went to go check on my car for damages. Water did happen to get inside the car, especially the backseats, the floor had about 2 inches of water. With a cup I scooped out all the water but was pretty hesitant to try and start it. But u did check if the electronics worked (lights, radio,dash board, etc) and it did. I even checked the oil to see if there was water that snuck inside (there wasn t), and the air filter to see if it was wet(it was dry)...so I thought it d be okay and left it alone for a couple hours.
Later on that day I went to just see if it d start, and when I turned the key, it wanted to turn on but nothing was happening and when I looked around the car, there was water coming out of the exhaust. So I left it alone for a while and came back to it about 2 hours later.
When I came back I twisted the key to the spot right before you crank it up and it made a clicking noise, so I took the key out quickly and did it once more but this time I just left the key at that position and heard the same quick clicking noise, moments later there was a noise that sounded similar to the an old computer desktop connecting to the internet, and followed by that I noticed the temperature jump from C (cold) to H (hot)..once I saw that I took the key out and here I am...
motingwedennis
May 4, 2018 05:09 AM
dlenoxx
Dec 2, 2010 12:05 PM
bobbyeg6
19
Feb 21, 2010 06:02 AM
